JapanIse
Re: JapanIse
Messagepar cbx » 24 Sep 2015, 21:08
Ce soir, comme tous les autres jours, je n'ai bu que de l'eau et du café :lol:
Je n'ai pas dit que le moteur n'est pas d'origine ...
Pour la revue technique voir sur LBC; Baybay ou dans les brocantes motos; le prix devrait être autour de 20€
Cette RTM concerne aussi certaines Ducati (750ss, 860GT, 900ss)
Re: JapanIse
Messagepar cbx » 25 Sep 2015, 14:51
Bjr;
J'ai enfin retrouvée ma doc Haynes qui dit :
The CG125 model (no identifying suffix) has the frame numbers CG125-1023061 to 1111090. Engine numbers are not available. Identified by its shrouded, external spring, frontforks, this model Was imported from June 1976 to May 1978.
The CG125K1 model has the frame numbers CG125-1114636 to 1162518. Engine numbers not available.
It differed most noticeably from the CG125 model in having front forks with internal springs and exposed stanchions, and was imported from May 1978 to March 1981.
The CG125-B model has the frame numbers CG125-1202755 to 1223689; its engine numbers start at
CG125E-1374586
. It can be distinguished from the K1 model only by its different paintwork and graphics and was imported from March 1981 to March 1982.
The CG125-C model has the frame numbers CG125-1272831 to 1286692; its engine numbers start at
CG125E-1513928 on
. Fitted with revised tail lamp, flashing indicator lamps, handlebar switches and the usual detail changes to paintwork and graphics. This model is also fitted with a higher compression engine and the (T)PFC carburettor for greater fuel economy. Note also that the ignition switch is combined in a new warning lamp cluster, mounted next to the speedometer. Imported from March 1982 to November 1984.
The CG125-E model has the frame number CG 125-1288790 to 1293380 and the engine numbers
CG125E-1689761 to 1694851.
Identical to the C model except for detail changes to the graphics, this
model was imported from November 1984 to April 1985.
Moralité les numéros moteur des modèles produits avant Mars 81 ne sont pas connus et le tien est dans ce cas :cry:
Regarde tes mails je vais essayer de t'envoyer la doc Haynes (mais vu le poids c'est pas sûr que ça passe) qui te permettra en outre de réviser ton anglais :D
Billy
Re: JapanIse
Messagepar Billy » 25 Sep 2015, 17:32
Salut Ise, félicitation pour ton achat....... désolé j'avais loupé tes postes dans la section 125
j'ai aussi la docu Haynes pour ta CG125 (en anglais de 1976 à 91) si cela passe pas avec cbx, par MP donne moi ton adresse Mail
Re: JapanIse
Messagepar Ise » 25 Sep 2015, 17:37
Fiiiiiine :D
So MY JapanIse is a CG125K1 :P I love it, 'cause it sounds like other Honda models, K1 K2 K3 etc until K1Ka :lol:
And I love it twice, knowing that the only numbers available are those of the frame :D My JapanIse is indeed "une ancienne des 70s" :D
Now will you please forgive me ? I must go and look for a dictionary, to try and understand springs and stanchions, which I had never talked about before today 8-)
( :D :D :D :D :D :D :D :D :D )
( :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D )
( https://www.youtube.com/watch?v=-r08HbdAL4U )
Re: JapanIse
Messagepar Ise » 25 Sep 2015, 17:42
Yo Billy :D
Merci je sautille de joie !!! :lol:
Merci à vous deux, d'accord je regarde demain, et surtout j'essaie d'imprimer au boulot dès lundi...
Et Billy, as-tu celle des Amigos aussi ? Parce que sur la bourse de Frontignan j'ai demandé à un vendeur et il m'a répondu que si il en avait une il la garderait :cry:
Faudra quand même que j'en aie des vraies de ces revues un jour... Pour comprendre la différence entre RTM et part-list :roll:
Re: JapanIse
Messagepar cbx » 25 Sep 2015, 19:34
Part Lists : schémas, liste et références de toutes les pièces constituant la moto :: pour commander les bonnes pièces
RTM = Revue Technique Moto : comment démonter/remonter, réparer
Billy
Re: JapanIse
Messagepar Billy » 25 Sep 2015, 21:24
oui j'ai pour l'amigo ....par MP ton adresse mail ;)
Re: JapanIse
Messagepar Ise » 26 Sep 2015, 08:31
Bonjour ! :D
Impeccable ta RTM CBX, vivement lundi que je l'imprime, merci :D
J'ai reçu aussi ton mail Billy, je te dirai, il faut que je regarde ce que j'ai déjà car j'ai des choses aussi, mais c'est incomplet :D
Bon et sinon voici les dernières photos :
Cocotte à changer donc
Et le pot ?
Eh bien si on me demande mon avis, j'aimerais mieux un pot en meilleur état... On va chercher ça ;)
Billy
Re: JapanIse
Messagepar Billy » 26 Sep 2015, 08:36
Ok donc si tu as bien reçu mon mail, je t'envoi (au soir ou demain) ce que j'ai et tu feras le triage
Bon week à tertous ;)
Re: JapanIse
Messagepar Ise » 26 Sep 2015, 08:52
OK Doc, merci Billy :D
Sinon pour la selle
Je regarde Baybay pour la housse et je ne vois que ça :
http://www.ebay.fr/itm/Honda-CB125K5-12 ... 235940eb2e
Ce ressemble mais c'est pas pareil
Un selle entière ? J'en vois une sur LBC bonjour le prix, et en plus c'est pas la même il manque les rayures sur le dessus
http://www.leboncoin.fr/equipement_moto ... tm?ca=16_s
Mais elle est belle
